Coding Challenge - Basic Calculator (homework hustle smackdown)
tl;dr Challenge: Make this and share your results to compare.
Stemming from a /LabVIEW reddit post I've ran down the creative rabbit hole trying to see how simple and effective I can make a LabVIEW calculator, presuming limited knowledge
AND I THINK YOU SHOULD TOO
Background: I was compelled to see how hard a seemingly simple challenge was for a student that got stuck on a professors homework (as was unethically asking for paid work for his homework)
But it really got me chewing on..."how hard is this really? What if I threw away my knowledge of Event Structures? Could I make it as simple as possible but no simpler?"
I'll post in a response below with my answer, but my challenge to y'all...
Think it's easy enough for a brand new user of LabVIEW to code up?! Show me what you do with the same constraints I put on myself. Let's see what kind of solution you jigger up.
Even something as simple as making the layout reminded me about several features that if you aren't told about, are hard to discover (like setting boolean action en masse)
Remember, as simple as possible but no simpler. 😉
What kind of model did you follow? RPN, TI 85?
I think all these subtle differences make this WAY more complicated than the professor realizes.
also... am I wrong, is this more simple than I'm thinking?
Message 1 of 9
(1,995 Views)
His image have no apparent relation to the actual problem, i.e. entering three values, choosing A and B and selecting an operation from a ring, them possibly compare with C.
In any case, I think there are plenty of "calculators" here in the forum from the last few decades, so it might be worth doing a search.
Implementing an RPN stack is easy, TI modes need to keep track of operation precedence and my TI-58 still does that wonderfully. 😄
The input should probably be a string (update while typing), so we need to filter non-numerics, but correctly parse minus and E, and edit operation (backspace, delete) etc. The question is also if everything should fit in DBL or of we want to do bignum stuff, e.g. Calc that is part of windows supports 30+ significant digits! We even see a "^" and factorial button here.
Message 2 of 9
(1,977 Views)
Hmmm, I'm going for minimal LOC (and effort) here to make a functional calculator  🙂
______________________________________________________________
Have a pleasant day and be sure to learn Python for success and prosperity.
Message 3 of 9
(1,843 Views)
If you want to resort to something like that, this is simpler:
Message 4 of 9
(1,824 Views)
Indeed, well played. These days I have the uncontrollable urge to use python for anything everything I can get away with 🙂
There was something in the OP about not using event structures.
Message 5 of 9
(1,813 Views)
a rare usecase for labview's express .vis palette:
https://www.ni.com/docs/de-DE/bundle/labview-api-ref/page/vi-lib/express/express-arith-compare/formu...
Message 6 of 9
(1,602 Views)
As mentioned in that thread, i think OP misunderstood the assignment, i believe it's just a simple Case-training exercise.
Qestit Systems
Certified-LabVIEW-Developer
Message 7 of 9
(1,591 Views)
Note that the "Formula" Express VI isn't really an Express VI.  It's an XNode masquerading as an Express VI.
Message 8 of 9
(1,586 Views)
exactly, except that your A and B assignment is fixed while the problem description should allow choosing which number is e.g. A.
Quote from the link: "Ask to the user to choose one of these as A and another one as B. "
We could use an event to swap the legend, for example.
(Of course once you choose one, the other one is also defined, unless you also allow A:A, A:B B:A, B:B ...)
Also the entire terminology is a bit ambiguous, because a "Basic calculator" is not the same as a "BASIC calculator" 😄
Message 9 of 9
(1,355 Views)
