12-04-2007 03:07 PM - edited 12-04-2007 03:07 PM
12-04-2007 03:23 PM
"I've often been told that coerce dots are bad. "
That is how they are presented too noobs, and under many cicumstances they can be a sign of something bad.
Good or bad depends on were you find them and waht they are doing to you.
I think the only "global statement" I can make about them is that they are always a sign that LV is doing some type of conversion and you should think about what their presence means.
In this case, it is the typedef that is bringing ou the dot. A non typedef data type must be coerced into a typedef'd form.
So the image you shared is more of "FYI" than a "Watch out".
Ben
12-04-2007 03:48 PM
12-04-2007 03:49 PM - edited 12-04-2007 03:50 PM
yes, no negative.
Ben
12-05-2007 10:46 AM
12-05-2007 11:18 AM - edited 12-05-2007 11:19 AM
Hi Christian,
Take a look at this diagram.
It appears that coercion and buffer copies do not always go hand in hand. What puzzles me is why coercion in one case but not the other?
This is LV 8.2.1 BTW.
I'm stumped!
What do YOU think?
Ben
12-05-2007 11:27 AM
Here are the files I used for the previous post.
Ben
12-05-2007 01:47 PM
12-05-2007 03:43 PM
Hi DJ,
I made a phone call and this is what I heard back (with some didaction (sp?)
Hi Ben,
This is Noah from National Instruments. I have been doing some more
research into your question about the coercion dot with writing string
values to Type Def string values. I believe I have an answer for you.
What we were seeing in your post was that the coercion dot was present
basically whenever we had two different sources of the string going to
the two separate Type Defs, or when the wire was “branched off” and the
buffer allocation was showing up in the Match Pattern VI.
After testing it out some on my own along with talking to some other
engineers around me, I see a similar result, but I believe I have the
reason why. When the string is being written to the Type Def and coming
from the same source, or not “branched off,” the coercion dot does not
show up and the buffer allocations appear inside of the Bundle By Name
function. This is expected behavior because the cluster is just acting
as a pointer to the actual data having the string data come from two
different sources where it is “branched” means that the copy is created
in memory before it reaches the Bundle By Name VI. However, when the
String data comes from the same source, the coercion actually takes
place inside of the Bundle By Name VI. I know that you said you were
seeing this in LabVIEW 8.2.1, so I tested it out in 8.2.1 and 8.5.
Using the Always Copy VI in 8.5, I can see that the coercion dots show
up on the Bundle By Name VI like they do in the top portion of your VI.
This VI simply forces the buffer allocations to be made before the
Bundle By Name VI is reached. So in summary, this is expected behavior
and has to do with the fact that the source of the string data is coming
from two different places, so the copies in memory are made before they
reach the Bundle By Name VI. I have attached an image that shows how
this looks in 8.5 with the Always Copy VI and Buffer Allocations shown.
I hope this answers your question and clears it up a little. If you
have any more questions, please feel free to call back and we can take
this further. Also, if you would like for me to post on the forum with
this response, I will be more than happy to do so. However, you are
also welcome to post a response as you have been working on the forum
already. Please let me know if you would like for me to post my answer.
Thanks and I hope to hear from you soon!
Noah ... National Instruments
Applications Engineer
It will take some time to digest. If you can re-state this for the rest of us to understand.... Go for it!
Ben
12-05-2007 04:06 PM
