Coercian dot on power spectrum
Hello all,
Was just curious about why I have a coercion dot on my FFT Power Spectrum when suppling it a waveform?  I thought (and the detailed help agrees with me) that a waveform was the required type of input.  Maybe there is more going on here than I realize but clearly I don't see it.
As a sidenote I'm going this because I'm replacing an express VI in an application I was handed to finish up and the express power spectrum VI seems to give results that are off by the square of the input function.  Ok so that sentence makes little sense, so what I mean is when I hook a function generator up to my DAQ board and supply a sine wave of a known frequency the express power spectrum VI gives 16Hz instead of 4Hz, or 2500 instead of 50.  The normal power spectrum VI works fine.  Don't like Express VI's anyways but just curious.
Thanks in advance!
Message 1 of 12
(3,682 Views)
Code?
This shows no coercion dot:
Message 2 of 12
(3,677 Views)
Here's the relevant part of the code.  And yeah its messy...still testing it out at the moment!
Message 3 of 12
(3,664 Views)
Are you certain that t0 is in the correct format?
Jim
LV 2020
Message 4 of 12
(3,654 Views)
Well its the inverse of my sampling rate.
Message 5 of 12
(3,648 Views)
That would be dt.
Jim
LV 2020
Message 6 of 12
(3,646 Views)
Yeah it would...please excuse my inability to read!  The t0 is just coming in from a "Get Time/Date in Seconds"
Message 7 of 12
(3,643 Views)
Accepted by Dac83
Is the Y array DBL?  SGL or EXT would produce a coercion dot.
Lynn
Message 8 of 12
(3,633 Views)
Are the array and dt the same precision? i.e. dbl?
Lynn beat me to it.
Jim
LV 2020
Message 9 of 12
(3,630 Views)
Good call!  It was a single.  I put in a convert to dbl and coercion dot is gone.  Thanks a lot everybody!
Message 10 of 12
(3,627 Views)
