Collect data after iterations then save just the average of each y-data point
How can I collect data after n iterations (2D x-y data), then find the average of each data point of just the y-data and save the final data as the original x data and averaged y data.
hiNi
(2,689 Views)
You're going to have to provide a little bit more information.  Perhaps a sample of the data collected and how the data will look once  you have the data averaged.  (Is it by rows, by columns?  How large is the array in each dimension?)
(2,673 Views)
Attached is an example of the way the data is collected.  I would like to get the average of the Iterations for each row, then the result stored in the last column.
 hiNi
(2,664 Views)
Take your 2D array and transpose it, then feed it through a for loop to get the average of the resulting 1-D array.
Message Edited by Ravens Fan on 09-11-2008 03:13 PM
(2,655 Views)
