Color of error out of a property node
I have just noticed that the error out of a property node may be red or black. See below picture.
If I create a new property it will be black but if I copy the red one, it will remain red. What does this red color mean ? Any ideas out there ?
Message Edité par JB le 05-08-2008 03:35 PM
Message 1 of 8
(3,513 Views)
Right-click on the red version and you will see that the option "Ignore errors" is selected. Smiley Wink
Ben
PS: Mathan, See above. Smiley Very Happy
Message Edited by Ben on 05-08-2008 08:37 AM
Message 2 of 8
(3,502 Views)
Hai JB,
Is it reproducible? Have you deleted that property node and selected another again?
What version of LV you are using?
[Edited: Hey, yes Ben ur correctSmiley Wink. May be u can send it some 2 min beforeSmiley Sad. Anyway thanks.Smiley Happy
Mathan
Message Edited by mathan on 05-08-2008 08:37 AM
Message 3 of 8
(3,500 Views)
The difference arises only when there are multiple properties in the node: if the error out is black, an error in a property will prevent all other properties to be written/read; if the error out is red, LV continues to the nex property anyway. It's possible to change the behaviour (and so color) by right clicking on the node and selecting/deselecting "Ignore errors inside node".
Paolo
LV 7.1, 2011, 2017, 2019, 2021
Message 4 of 8
(3,493 Views)
Thank you Ben !
I'm a little bit ashamed to discover this option after more than 10 years LabVIEW programming !
Now I have to check tens of applications ! LOL
Message Edité par JB le 05-08-2008 03:43 PM
Message 5 of 8
(3,491 Views)
JB,
"A wise man goes into his storehouse and brings froth treasure both old and new." (Proverbs)
It sounds like you discovered a new treasure. Smiley Wink
Ben
Message 6 of 8
(3,483 Views)
"A wise man goes into his storehouse and brings forth treasure both old and new."
Smiley Very HappyWell said BenSmiley Wink
Message 7 of 8
(3,480 Views)
Thanks Ben,
I hadn't realized that.  I believe I had seen the red icons a couple of times, but not often.  I wouldn't even know how to search in the help to find the answer for that.Smiley Happy
Message 8 of 8
(3,469 Views)
