Color table with XY-graph
Hi folks
I'm using an XY-graph to draw a huge amount of lines or dots each representing a spearate object. I'd like to use the line or dot color to display some feature of the object similar to the Z-value of intensity graph. The thing is, I wouldn't like to program the excellent color-table Z-scale control that is used with intensity graph again. Is there any way to reuse this control. Is the code for the control hidden somewhere in the Labview library directory.
What I exactly need is a control to define the color table an a helper VI to use the color table to get the color value for a specific Z-value (DBL). And since somebody has already programmed this, I wouldn't like to reprogram the same thing. Any ideas?
Tomi Maila
Message 1 of 1
(2,678 Views)
