How to sort text file into array and back to string
I had a VI that was saving CAN messages based in their ID into 4 different files.
The VI was too complex to operate with my PDA so I had to use a VI that would dump all the messages in one single text file.
Now I am trying to create a VI that will open that file, read it, read each line and perform the sorting based on the ID.
I am having difficulties because if I open the file it is read as line of strings and I cannot find the right VI that will look one line at a time.
I tried to convert it to an array using pick a line, byte to array but it is not working.
My idea was to get the text file into a 1D array and then use a for loop with indexing to do the sorting.
Is there a way to look at each line consecutely?
Thanks a lot,
Fede
(4,359 Views)
This is the text file in question
(4,354 Views)
There are many ways to do this. Sorry, I am not familiar with these types of CAN messages, so I am assuming that the ID is the first three digit number after the time.
If the ID is always 3 digits starting at offset 17, you could do something like in the attached quick demo (only sorts 100 and 101, add more cases as needed). In a real program, you might want to open the four output files, the append to the correct one depending in the ID at each iteration.
(4,351 Views)
Thanks for the help.
I did not think about scan for tokens.
It works really well.
I am going to add 3 more cases and the saving structure
(4,336 Views)
