Combine 8 seperate bits to have a single 1 byte numeric
Hello..
Is it possible to concationate binary bits to have a complete 1 byte binary number.
Example;
1.  I have thease 8 bits -->  0,0,0,0,1,1,1,1  --> then binary should be 00001111
1.  I have 4 groups of 2 bits -->  00,00,11,11  --> then binary should be 00001111
Is it possible??
Please help..
(5,182 Views)
Accepted by topic author Nayan
There is Boolean Array To Number function in Boolean pallete.
(5,179 Views)
Hi Nayan,
You should have linked to your other thread
to convert an array of booleans into an integer number you should use "boolean array to number" function. Easy as it is!
All you need to do is to build your boolean array. There are functions like BuildArray
(5,176 Views)
Thank you PiDi and GerdW.. Smiley Happy
(5,159 Views)
