How would you import an Excel Spreadsheet of Data into Labview?
I'm working on a VI that needs to use 2 large 1D arrays of Data.  I was wondering if there was a way to take an excel file that is either a 1D vector or a 2D matix (2 columns by N rows) and and import the Daya in Array format into Labview for use in my VI?
(17,291 Views)
There is a "read from spreadsheet.vi" that will import the spreadsheet data into labview.  Do a search in the tools palate for it.
Brian
(17,285 Views)
Hi
If you want to select which data you want to read then you could also use Excel as ActiveX control and then you could read selected data to LV application.
bogdani
(17,281 Views)
Thanks for posting to the NI Discussion Forums!  There are a 2 main ways to get data to/from Excel – 1) use ‘spreadsheet’ files which are nothing more than some delimited data format, and 2) ActiveX.  I suppose a subset of (2) is the Report Generation Toolkit for LabVIEW but we’ll leave that one alone for now.  Searching for “Excel” on the ni.com website returned over 800 hits, so I believe that there should be tons of information out there on the subject.  After reviewing the documentation please let me know if you had any specific questions on anything – we’re happy to help!
Travis M
LabVIEW R&D
(17,266 Views)
Yes there is a lot of staf regarding to reading from Excel  files.
bogdani
Message Edited by bogdani on 05-03-2006 12:07 AM
(17,252 Views)
Hii NI Forum Members,
I would like to plot the XY graph  (2 vertical axes with pressure and temp and 1 horizontal axis time),in parallel the values are generated in excel sheet with 3 columns and with multiple rows.
Hence,How can i import the excel sheet columns and rows and plot the generated excel sheet values in XY graph of LabVIEW
Waiting for your vauable reply,
Raj
(8,552 Views)
Since you are new to this forum, please go through the quick intro on how to use this forum.
Please start a new thread for your question.
(8,542 Views)
