Combine VI into one VI
I am new to labview. I created four individual VI. I want to combine them into one VI, not sub VI. It is like normal user interface,all in one page.like press one button,the corresponding details shows. But in the same VI and same page.
Thanks in advance
Message 1 of 8
(4,526 Views)
If you want to combine similar vi's you can go for polymorphic vi
Message 2 of 8
(4,520 Views)
Accepted by feinimoshu
Hi Feinimoshu,
I think what you are trying to do is display your four VIs in a single front panel. For that you can have a main VI with a Sub Panel in its front panel and dynamically call your four VIs as required. You can view all your VIs in the same front panel in this way.
Nitz
(Give Kudos to Good Answers, Mark it as a Solution if your problem is Solved;))
Message 3 of 8
(4,514 Views)
NitzZ:
thanks, it is something like this,but I am not familiar with subpanel, would you please send me an example for me,or tell me how to connect in detail?
what is VI ref connect to ?
thanks very much
Message 4 of 8
(4,503 Views)
You can r-click a sub-vi and create ref, that ref is connected to Insert subpanel.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 5 of 8
(4,492 Views)
Check this example. A simple one of calling a vi into a sub panel.
Nitz
(Kudos are always Welcome;))
Message 6 of 8
(4,465 Views)
NitzZ :
sorry, I can not open the file.different version.Mine is 2009(9.01)
Message 7 of 8
(4,459 Views)
This is in 9.0
Nitz
(Kudos are always Welcome:smileywink:
Message 8 of 8
(4,455 Views)
