Combine two graphs into one graph
Hello there! Ive posted a similar question a week back, and ive tried to do so using the suggested way, but so far my efforts are failed. 😞 Can someone please help me. Here i attached the .vi data for the program ive made.
my only problem is, i have two curves so far Current curve and Voltage curve. I need another additional graph where in it there are 2 curves together - both current and voltage.
I tried using 2d arrays but i got a warning message saying my input datas are not coherent. someone help. Im still new in this and i dont know what else to do. 😞
Thanks so much
(3,976 Views)
can you post your code in LV2009?
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(3,970 Views)
Okay... I will do it.. But how do i post the code in LV 2009? I only have version 10 installed. :-s
(3,966 Views)
Hi apapa
Goto File --> Save for previous version. Set the version.
And press Ok...
After that don't open that converted file. Just Post it....
But I think if you use the advanced features, applicable only in LV10  will not come in lower versions....
<<Kudos are welcome>>
Step out of your comfort zone to experience the real you!
(3,962 Views)
This should work.
Tim
GHSP
(3,944 Views)
It works!!! Thanks soooo muchhh!!! :)))
(3,929 Views)
