I wonder if someone can help me to design a VI that will be capable of detecting and displaying the start index and the length on each patch. There are 3 patches each one of them contains number of successive elements less than1.
Attached is the sample data to be used.
 Please!!!!
Message 1 of 9
(4,524 Views)
I wonder if someone can help me to design a VI that will be capable of detecting and displaying the start index and the length in each patch. There are 3 patches each one of them contains number of successive elements less than1.
 Please!!!!
Message 2 of 9
(4,523 Views)
school project?  Question was asked a couple days ago here.
Paul
Message 3 of 9
(4,514 Views)
Is this homework?
It sounds an awful lot like this recent message thread. http://forums.ni.com/t5/LabVIEW/Urgent-Help-please/td-p/1291098
Message 4 of 9
(4,508 Views)
that's same one but i have done 1&2 i just need 3. if you know please!!!
Message 5 of 9
(4,456 Views)
You have to make an attempt to solve the problem. Do you think your professor does not monitor the forum? What do you learn if someoone does your work for you?
Message 6 of 9
(4,432 Views)
Attached is what I have done so far.
I got the index numbers, and now I only need the number of element for the thin patches. it sould look like this:
Index 13 ------- 5 elements
Index 46 ------- 5 elements
Index 61 ------- 4 elements
Message 7 of 9
(4,351 Views)
Maintain another shift register that counts how many elements are below the threshold.  Whenever an element is below the threshold, add 1 to the counter.  When it goes back above for the first time,  Put the counter value into another array in a shift register and reset the counter to zero.
Message 8 of 9
(4,333 Views)
Just Print
Richard
Message 9 of 9
(4,320 Views)
