Combine two programs
I am working on saving this to 8.0. It is giving me some trouble. I was here late last night and forgot to save it to 8.0 before I left.
Tim
GHSP
Message 21 of 24
(1,360 Views)
It seems that there is a known bug for saving a program with an event structure back to 8.5 or below. THe work around is very time consuming. I will see what I can do but I can not promise that I will be able to get to this any time soon. Sorry.
Tim
GHSP
Message 22 of 24
(1,361 Views)
Hi I have tried to use the event structure for operating just one button of my program but at present once I press the left button it gives the pulse I want at the frequency I want but then gets stuck and I can't get it to stop. When I press the button it stays pressed even though I have it set to switch until released.
Is it something to do with the loops I have used?
Message 23 of 24
(1,333 Views)
The way you have it set up is not the best way to do what I am talking about. Here are screen shots of the code that I put together for you. Look through it I am sure that you are going to have questions but it is a much better way of doing what you are try to do.
Tim
GHSP
Message 24 of 24
(1,314 Views)
