Combining Arrays (One 1d and One 2d)
Hello. I recently started using LabVIEW so I have little knowledge on how to do this.
I have a 1d array that reads out time values and then a 2d array that reads out voltage values for those times. I want to combine these two arrays so that when I make a Write to File, the file would show  time on one column and voltages on the other columns on Excel. I tried searching for answers but I only found solutions to combine/concatenate 2d arrays.
I hope my question is clear since I don't really understand everything on the program yet. If it helps, I added my test vi.
(1,691 Views)
Accepted by bagelbites
I am also recent to LabVIEW so I put this as a disclaimer that my code will probably not follow best practices.
I also haven't looked at your code since I am using LabVIEW 2015. I don't add the 1D array to the 2D array but instead build a new one from the 2 others.
Hope it helps 🙂
Andeagon - LabVIEW 2015
(1,670 Views)
Thank you for this. I ended up figuring it out by doing the same you did but it's nice to have confirmation.
(1,624 Views)
