Combining Radio Button logic and Ring Control Logic.
I want to control ring control items based on the selection of radio buttons.
How can I do that
Message 1 of 10
(4,924 Views)
Which control do you mean? You mean text ring controls?  You can use a value property node. From the radio buttons you can make a value and write that to the property node.
Message 2 of 10
(4,921 Views)
Hi krjasani,
I guess you want to change/set ring items based on some conditions: use the "Strings[]" (or "Strings and Values []") property of the ring…
Message 3 of 10
(4,914 Views)
Thanks for response.
I want functionality where if user select Radio Button-1, then select item from list-1 like wise.
Please see attached snap for understanding.
Message 4 of 10
(4,911 Views)
Hi krjasani,
to set ring items you should use the "Strings[]" property…
Message 5 of 10
(4,901 Views)
Message 6 of 10
(4,899 Views)
2018-12-19 13_59_41-Untitled 1 Block Diagram on Modbus Library.lvproj_My Computer _.png2018-12-19 13_59_41-Untitled 1 Block Diagram on Modbus Library.lvproj_My Computer _.png
Message 7 of 10
(4,896 Views)
Hello, Can you share VI ?
Message 8 of 10
(4,860 Views)
Combining Radio Button logic and Ring Control Logic.pngCombining Radio Button logic and Ring Control Logic.png
Omar
Message 9 of 10
(4,843 Views)
Message 10 of 10
(4,837 Views)
