Combining a chart's image JPEG with a text label?
Hi
I am creating a JPEG file of a chart's plot. This works fine using the 'Write JPEG File'.
As I have 8 charts in the VI to save to file, I have identified eact one using the label text. This appears OK when running but after saving the charts to file there is just a black rectangle (see attachment.
Anyway around this?
Thanks Harry.
(2,683 Views)
This is because the background color defaults to black.
Wire a color box to the BG Color input of the Get Image method.
Or, make the label white.
Or, use a purple or green color as background, and Create Mask to mask out
that color.
Or, put the label on the graph instead of above it.
Wiebe.
(2,651 Views)
