make selectable the disabled items of a ring
I have a ring with some disabled items and I would like to make them selectable, is it possible?
ToNi.
Message 1 of 9
(4,830 Views)
NO.
- Partha ( CLD until Oct 2027 🙂 )
Message 2 of 9
(4,828 Views)
"NO. "
Just write an empty array to the "DisabledItems" property to enable all items.
Ben
Message Edited by Ben on 09-13-2007 07:41 AM
Message 3 of 9
(4,811 Views)
I think that the NO means that a disabled item can't be selectable. You have to enable the item to make it selectable.
Therefore the importance of wording correctly a question to get a useful answer.
LabVIEW, C'est LabVIEW
Message 4 of 9
(4,801 Views)
First of all sorry for my bad explanation. I'll try to explain you better.
Well, I have a Dialog ring, and the user selects items. Each time the user select an item, that item become disabled. But, I would like to do the following: I would like, the user could select the disabled item and make it enabled in run time, but I know this is not possible to select a disabled item.... but I need to do something like this, something that allows user to enable a disabled item in order to select it.
Any ideas?
Thanks in advance to everybody,
ToNi
Message 5 of 9
(4,761 Views)
Well, as you figured out the purpose of "disabled" is to prevent an entry from being selected. Depending on the specifics, you have a few options, e.g.:
Make one ring entry "enable disabled items" which would trigger Bens's code when selected.
To surgically re-enable only one entry, things get a bit more complex. Do you really want to disable the items are are you just looking for a visual cue that an entry has been selected before? In this case you might be able to use a listbox where you could change the font to grey for entries that have already been processed once when double-clicked. Another double-click could revert them back to black.
Attached is a simple draft (8.0). Modify as needed.
Message 6 of 9
(4,755 Views)
Sorry but I use LabVIEW 7.0 Express, so could you attach it in LV7 Express please?
ToNi.
Message 7 of 9
(4,711 Views)
Ben,
Jean Pierre exactly said what I meant. Smiley Happy
ToNi,
You cannot do what Altenbach has suggested because the Active Row property is not available even in LV 7.1... Smiley Sad
Moreover, the Mouse Down event does not get fired when clicked on a disabled item of a ring.
Message 8 of 9
(4,694 Views)
Hi ToNi,
you may use a listbox manipulating the item symbols, see the attached example in LV 7.1.
Please note that many other symbols are available.
Hope this helps.
Paolo
LV 7.1, 2011, 2017, 2019, 2021
Message 9 of 9
(4,687 Views)
