Combining two intensity graph
I have two two 2D arrays. First one is an ''image'' and the second is extra information about that image. For exemple, imagine I have a black and white image of a beach and I want to add with color where a metal detector detected something on the beach. I want the pixel on the image to be redder with the intensity of metal detected. In a way, I'm trying to superpose the information of an image and a detected property at certain position on that image through colors.
From a more math point, the way I could imagine it being done, I start with one of my black and white pixel and use it's RGB value: 30/30/30, and I modify it. If the value in my second matrix is high, I'll display RGB: 90/0/0, if it's low, I'll keep the 30/30/30.
Is there a way of doing this sort of thing? Have anybody ever tried something similar?
Thank you.
RMT
(2,700 Views)
Note that intensity graphs have only a 256 element color map for the z axis, so you cannot operate on RGB values the way you want. Maybe you want a picture indicator instead.
Instead of adding red, You could do a simple binary masking operation and remove (set to zero) the G and B component
(2,695 Views)
Accepted by RaphaelMT
For an intensity graph, you could "cheat" by creating a custom color ramp that goes from black to white for the even elements and from black to red for the odd elements. Scale your values into U8 arrays and round all regular values down to the next even element, then do a +1 on all element that should be red.
(2,680 Views)
