Combining two signals for dither simulation
I am trying to combine two different simulated signals into one. When I use the
Merge Signals function, I do not appear to be getting the results I am
desiring. On the Waveform Graph it is appearing as two separate signals. How do
I combine signals to merge into one? What am I misunderstanding about the Merge Signals function?
Note: I am trying to simulate an output signal that has a dither frequency riding on top of it.
(3,615 Views)
Accepted by topic author hrsnblm
Hi hrnsblm,
what about adding your signals?
Using basic functions instead of ExpressVIs might give greater insight of the things you are doing…
(3,613 Views)
had wondered if a basic function would be simpler, but hadn't tried. Thanks for the thought.
(3,609 Views)
