while loop
I have a Input string "1.15;10;1.25;20;1.35;30;1.45;40".  i need to seperate the data, use a For loop i need to input the Iterations
the String length will change.
I want to use a While loop and have it stop when there is no more data.  i can only get it to work when i use a stop button.
thanks
(4,891 Views)
Hi JWT,
you only need a FOR loop:
(4,887 Views)
Why use a loop at all?
Use Split Strings.vi
Its in vi.lib\Advanced String\
There is even a Free Toolkit called "Hidden Gems" that sticks some of those useful vis on the functions pallets.
@Gerd:  What's the loop for?Smiley Surprised
(4,883 Views)
Hi Jeff,
I made that snippet before even looking at JWTs VI.
In the message the words "FOR loop" and "WHILE loop" came up, so I included AUTOINDEXING in the snippet…
(4,878 Views)
Thank you
JWTIII
(4,868 Views)
Thanks are given with kudos, and marking the appropriate answer (or more appropriate) in the thread.
(4,844 Views)
