Command Line Arguments to VI Without Building EXE
I am following this guide: Passing Command Line Arguments to a LabVIEW Executable
I want to pass command line arguments in Windows to LabVIEW without building my project into a EXE.  I just want to pass them to a VI which is set to Run When Opened.
This is my LabVIEW code:
However when I call my VI using the command line, I do not see my user-arguments:
"C:\Program Files\National Instruments\LabVIEW 2009\LabVIEW.exe" "C:\Desktop\LabVIEW Code\test.vi" -- test arg1 arg2
The above call only yields "LabVIEW" as the first command line arguement.  I don't see "test", "arg1", or "arg2" in the Command Line Arguments array.
If someone helped you out, please select their post as the solution and/or give them Kudos!
Message 1 of 9
(6,688 Views)
Hi Happy
There's a working example in C:\Program Files\National Instruments\LabVIEW 2010\examples\viserver\cmdline.llb.
Not sure if it's in LV 2009 ?
Good luck !
Message 2 of 9
(6,652 Views)
@NeilR wrote:
Hi Happy
Good luck !
This example file uses the same approach as above, however it also does not work:
"C:\Program Files\National Instruments\LabVIEW 2009\LabVIEW.exe" "C:\Program Files\National Instruments\LabVIEW 2009\examples\viserver\cmdline.llb\CommandLine.vi" -- /number:4.000000
Output:
Message 3 of 9
(6,647 Views)
Check into the examples for Asynchronous Call By reference.  Essentially you need to open a vi server reference to the vi with the right flags set.  the help on open vi server reference will explain the flags.
Message 4 of 9
(6,635 Views)
Would you be able to create an example?  I found this: Asynchronously Calling VIs but it seems to only address running a subVI in an asynchronous manner.  It doesn't explain command line arguements passed when the VI first runs.
Message 5 of 9
(6,623 Views)
Accepted by MrHappyAsthma
Hmmm ... that's disappointing. I've just tried it with LV 8.5 and it's fine with that too.
I've been running these under XP SP3.
I assume you completely closed Labview before running the command line ?
Message 6 of 9
(6,615 Views)
Mr. Happy
I could respond with a volume or a simple example.
What do you want to accomplish?  What have you tried?  And, I know the help file can make you gyrate unexpectedly.
Message 7 of 9
(6,612 Views)
I am using Windows 7 and LabVIEW 2009.
I do, indeed, close LabVIEW completely before trying to run that example.
All I need is a way to execute my VI and pass it some custom parameters using the double hyphen (--).
EDIT:
I finally got it to work.  The "closing out completely" did the trick.  For some reason a LabVIEW process was still running in the background...  But I force closed it with Task Manager and now it works!
Message 8 of 9
(6,603 Views)
Yep ... it should be easy. I sense your frustration.
Just tried the same example with LV 2012 running under Windows 7.
Same result. Fine. Smiley Frustrated
EDIT: Just seen your edit. Good news !!
Message 9 of 9
(6,591 Views)
