Command Line support
You are right
Message 11 of 14
(1,012 Views)
Most of the problem is clear, except the actual problem.
@lvbms wrote:
Surly, if I type "ipconfig" from the command line, it returns to the command line?
I'd expect the LabVIEW exe to behave the same: if the exe quits, the command line should be returned to the user.
Not sure if there still is a misunderstanding, or that this is how CL behaves, or if it's something you or the used library caused... Can you post a (minimal, complete and verifiable) example?
Message 12 of 14
(994 Views)
If I type ipconfig in this example it returns everything I would expect it to return.
Tim
GHSP
Message 13 of 14
(985 Views)
@lvbms wrote:
You are right
Actually, no, that's only normal if you already have the command line open from the beginning.  Any other time, it opens up the CLI, completes the task, then closes it again.  (Try running "ping" from the run window.)
Bill
CLD
(Mid-Level minion.)
Message 14 of 14
(963 Views)
