Command line arguemts expansion at run time
Exactly that is my point. Do you have any link regarding that.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 11 of 31
(1,459 Views)
Hi Ranjeet,
you should have noted your point in the beginning...
No, I don't have a link at hand, but you can search the forum for "OpenG" and "Pipes"...
Message 12 of 31
(1,457 Views)
May be my words were not correct.
Thanks for your concern.
--Ranjeet
Message 13 of 31
(1,455 Views)
Ranjeet_Singh ha scritto:
Hello all,
                I am programming PIC IC using command line and passing arguments. In that If I pass the complete syntax then it does all the process and ends with programming. Now I do have a requirement in which I need to program multiple ICs.
My command line syntax is
cmd /c ICD3CMD /P18F26K22 /E /M /F"D:A.hex"  -- This will do all the job from starting to end.
Here programming is done using argument M/F"D:A.hex"
When I need to program multiple ICs then I only need to pass M/F"D:A.hex" as arguments to system exec. How to achevie this?
It's very likely that M/F"D:A.hex" as an argument of a command line program is not valid.
Try with /M /F"D:A.hex".
The full command line would be
cmd /c ICD3CMD /M /F"D:A.hex"
I'm suggesting this without knowing anything about the programming application.
Paolo
LV 7.1, 2011, 2017, 2019, 2021
Message 14 of 31
(1,446 Views)
pincpanther..I just want to tell about argument....
--Ranjeet
Message 15 of 31
(1,444 Views)
I don't understand. I was talking about the argument too.
So what's the full command line you are trying?
Paolo
Message 16 of 31
(1,444 Views)
See my fisrst post. That is complete syntax.
/M/F"A.hex" is the arguments that need to be passed each time.
--Ranjeet
Message 17 of 31
(1,435 Views)
Hi Ranjeet,
you cannot call SystemExec with just arguments. You have to give a full command with it's argument!
When you have to submit new arguments again and again, then what's the problem in calling the (full) command repeatedly?
Message 18 of 31
(1,431 Views)
Sounds like this may be something similar to what mySQL does when you start a command line session by running mysql.exe....The command prompt changes to
mysql>
until you type 'exit'....which returns you back to standard prompt.  Sending another command to SystemExec using only parameters is not going to use the existing session.
aputman
Message 19 of 31
(1,417 Views)
@GerdW wrote:
Hi Ranjeet,
This take 25 sec each time. When I will pass the only arguments which needs to be passed each time then it will take 2-4 sec.. Becasue if I pass all the argument each time it does all the thing from initialization till programming which lasts for 25 sec. Only programming takes 2-4 sec.
--Ranjeet
Message 20 of 31
(1,406 Views)
