Command line arguemts expansion at run time
Hi
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 21 of 31
(1,586 Views)
When I use command
C:\Program Files\Microchip\MPLAB IDE\Programmer Utilities\ICD3\ICD3CMD -b -p18f26k22 -v5 -e -m -f"D:\hex_file.hex"
from command prompt then it is working reliabely. But when I am passing through system exec then there is no error but no message also comes out.
--Ranjeet
Message 22 of 31
(1,577 Views)
Hi GerdW,
                     I am able to program but now I am facing some problem
1. When I set wait until true then output will be available only after completion or when user stops the application
2. If I set wait until complete false then output comes parallly in command prompt but not availbe in labview standard output.
This is as mentioned by help page but I need to display the message in labview standard output parallely.
How to acheive this?
--Ranjeet
Message 23 of 31
(1,561 Views)
Hi Ranjeet,
  maybe this thread can help you.
Paolo
LV 7.1, 2011, 2017, 2019, 2021
Message 24 of 31
(1,557 Views)
This is what I was looking for but how to do this?
--Ranjeet
Message 25 of 31
(1,554 Views)
It's written in the thread's solution. Did you read it?
I guess you are able to read a text file by code.
Paolo
Message 26 of 31
(1,550 Views)
I read it. but my doubt was if I want to create the installer for this application then I need to enter IP address for all the PCs.
Will ping<IP ADD> A.txt will read all the data of file A.txt. What will be path of text file and from where I need to call this PING?
Do you have any example for that?
--Ranjeet
Message 27 of 31
(1,545 Views)
Your interpretation is too literal. PING was only an example of a command line application generating text to the standard output.
Replace PING with your ICD3CMD utility with the proper command line. Try redirecting its output to a file manually from the command prompt.
If it works this way, you will be able to implement standard output catching by code.
Paolo
Message 28 of 31
(1,541 Views)
I though you already tried this..Will try this
--Ranjeet
Message 29 of 31
(1,534 Views)
I tried but unfortunately this is not working
C:\Program Files\Microchip\MPLAB IDE\Programmer Utilities\ICD3\ICD3CMD -b -p18f45k22 -v5 -e -m -f"D:2003.hex" > D:\path1.txt
I googled about redirecting and they say > is the command but not succedded.
--Ranjeet
Message 30 of 31
(1,523 Views)
