Command list for PL303QMD-P power supply
Is there command lis for PL303QMD-P PSU?
E.g.: command *IDN? works, but OUTP ON does not.
Any suggestion how to control the instrument?
Kind regards,
Balázs
(2,821 Views)
Accepted by topic author LTBALAZS
Let me know if This might help you.
CLD Using LabVIEW since 2013
(2,811 Views)
A little trick for the OP. There is something called Google. If you enter just the device name you can get lots of links that will be marketing material and more. If you add “manual” things start to get interesting but will for many devices mainly show you user manuals which normally tell you how to push buttons on the device but not the programming interface . But if you add “programmer” or “programming” too, you are bound to get a few links that contain the right manual unless the manufacturer believes that their manuals are top secret and can not be put on their web site because a competitor will steal them. 😀
So just for the fun try google with “PL303QMD-P programming manual”. I get the manual in the first link directly from the TTI website that way.
Rolf Kalbermatter  My Blog
(2,800 Views)
Yes, thanks!
(2,736 Views)
