improving SNR of sensor signal
I have one question regarding the improvement of SNR and phase measurement of signal.
As we know we can improve the SNR with Averaging technique. My question is if we have only 1 signal that has buried Sound/ Eco. How we can remove that sound weight from the signal so that i can get the clean signal.
For the reference of signals find the attachment.
(2,458 Views)
A low pass is often used to improve SNR, but if by "one signal" you mean one frequency (or range of)  then a band pass filter would probably work better.
=== Engineer Ambiguously ===
(2,385 Views)
Yes, it has a range of frequencies. i will use BPF and let you know it helps me or not.
(2,252 Views)
Are you going to use software filters or hardware?
__________________________________________
The best way to thank, is to give KUDOS
(2,237 Views)
Yes, Software filters of LabVIEW
(2,223 Views)
Seems we are missing details here. Please share what is the goal, what should be done, and more details about signal properties.
(2,177 Views)
