Commanding a solenoid and monitoring the output voltage
Hello!
I need to control and command the 120VAC solenoid through a DC-AC relay, how can I write codes in LabVIEW to switch ON/OFF the solenoid and monitoring the output voltage?
I got a USB-6002 and 1-channle DC5V relay module.
Thanks!
(592 Views)
You might not want to wire your USB-6002 directly to either the 5V Solenoid or the "output voltage (which I assume means 120 VAC, frequency unspecified).  What practical knowledge (or course instruction) do you have about capturing and generating signals?  Have you had a EE course on Signal Theory, and/or "practical design" for acquiring and generating signals?
Does DAQmx mean anything to you?  If not, I recommend "Learn 10 Functions in NI DAQ-mx and Handle 80 Percent of your Data Acquisition Applications".  Do not follow the advice in the first section -- avoid the Dreaded DAQ Assistant!
  • I just noticed that a Web search for "Learn 10 Functions" returns both a HTML document, which is how I learned DAQmx, and a Video, which may be easier to digest, but is "much less filling".
Bob Schor
(585 Views)
@Al1524 wrote:
Hello!
Thanks!
Assuming that you got a 1-channel arduino compatible 5V relay, like the one pictured below (contains a transistor to control the relay),
Connect the following pins of relay module to 6001 as follows,
VCC -> +5V
GND -> DGND
IN -> any Px.y (like P0.1, read as Port 0, Line 1)
To control the relay, you can set the digital state of the Px.y using DAQmx APIs. Checkout the following example from Example finder.
Santhosh
Soliton Technologies
(552 Views)
