Comment retreindre un chemin absolu?
Bonjour,
J'ai créé une application sous LabView dans laquelle l'utilisateur
est amené, à un moment donné, à selectionner le chemin de sauvegarde de ses données.
J'aimerais ajouter le chemin de départ et le restreindre, c'est-à-dire, imposer le chemin absolu de sauvegarde.
Avec la commande "chemin", j'ai ajouter le chemin de départ dans propriétés.
Lorsque l'on clique sur le bouton parcourir, on a bien le chemin de départ qui est sélectionné dans la boite de dialogue.
Cependant on peut changer de répertoire.
Comment interdire cette option?
Merci de votre réponse.
Message 1 of 10
(4,064 Views)
"Mala kahi kalat nahiye .Jara english madhe lihnar ka?" Smiley Sad
(Will you please write in English so that we can understand your problem)
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
Message 2 of 10
(4,063 Views)
I am creating an application, in LabView,that allows users to choose the path to save their data.
Now, I would like to impose the path for the storage so that users can only create a directory or file from this.
I don't know how to do.
Thank's for your help.
Message 3 of 10
(4,046 Views)
Hi FLEURYNS,
You have to connect path for that. can you post your code aor image so that I can help you.
As i do not know which labview function you are using, I am attachin one example
Hope this will help.
Gaurav k
CLD Certified !!!!!
Message 4 of 10
(4,040 Views)
Whenever you are using file function, If you are not connecting any path to its input it will ask user for the path.
Otherwise it will not. I hope you understood what I want to say.
Gaurav k
CLD Certified !!!!!
Message 5 of 10
(4,038 Views)
I think restricting the possible selection is difficult, once you use the Windows-Subvis to select a path.
I don't know of way way to do so.
You might try to to rebuild something similar in LV. But.....
GT
7.1 -- 2013
CLA
Message 6 of 10
(4,027 Views)
Accepted by FLEURYNS
"Mala kahi kalat nahiye .Jara english madhe lihnar ka?" :smileysad:
Gaurav k
CLAD Certified !!!!!
lol
Well,
It seems like the question is about how to prevent the user from accessing another directory in the file open dialog of LabVIEW ?
You can't do it with the Open File VI of LabVIEW. You have to recreate your own Open File dialog that will check if you are changing directory.
Even in .NET you can't. I think that using Windows API (Win32 dll) you can but this is not the best (using a flag like NOCHANGDIR).
Da Helmut
Voir le profil de Maxime M. sur LinkedIn - View Maxime M.'s profile on LinkedIn
Message 7 of 10
(4,024 Views)
I think too.
So , I'm gonna try to use a case structure in order to display an error
message when user create its directory in another path.
Thank you for your help.
Message 8 of 10
(4,016 Views)
Sorry...I misinterpreted the problem.Smiley Sad
Gaurav k
CLD Certified !!!!!
Message 9 of 10
(4,008 Views)
Never ind.
Message 10 of 10
(4,002 Views)
