Communcating wth a thermotron 8800 via ethernet
Does anyone have experience communicating with a thermotron 8800 controller via Ethernet?  I am new to labview so please be as detailed as possible.  The goal is to pull thermocouple data from the controller and log it to a host pc.   The thermotron is currently connect to our network (DHCP).  an example vi would be most helpful.  Thanks mic3030
(3,905 Views)
mic3030,
I am not familiar with that specific instrument, but I would certainly recommend using Instrument Drivers for this particular task.  I checked and Thermatron does have some LabVIEW drivers for the 8800, so I would take a look at those and see if they work for you.  If they follow the Instrument Drivers template there should be an example with them.
Hope this helps!
Andy F.
(3,893 Views)
Thank you for your response.  I went to the Thermotron website and downloaded the drivers for Labview, not the CVI ones.  There was not an example with the drivers.  I am extremely new to labview, can you outline some steps to get started?  Thank you.
(3,880 Views)
Hey,
Before you start working on your application, I would recommend you to follow the links below to quick learn LabVIEW. It should not take a lot of time. Once you understand the LabVIEW programming environment, then you would be easily able to understand what the Instrument Driver for your hardware is all about.
Link 1
Link 2
Chetan K
Application Engineer
NI
(3,853 Views)
