 Siddu436
			Siddu436
			06-14-2006 01:21 PM
Solved! Go to Solution.
06-19-2006 02:45 PM
Hi Sathya,
I am not familiar with your instrument or the driver, but most of time, drivers will have options for any type of interface your instrument has. For example, if your instrument has a serial and a GPIB interface, most drivers will provide ways to use both (ie. a Serial route and a non-serial route). I found this driver on the Tektronix website. I cannot download it without a user account. Is this the driver you found? Please check to see if it has a serial option you can use. If not, you may have to develop your own driver using the I/O Assistant or the VISA API. All you will need to know is command set of the instrument and you should be able to communicate.
Please let me know if you have any questions!
