Communicate with Delta PLC (DVP28SV) using Labview over TCPIP ethernet
I want to communicate with a Delta (DVP-28SV) PLC over TCP/IP Ethernet using Labview.
Labview does have a OPC server (with SCADA module) but I do not want to use it.
Ram Prakash
(8,528 Views)
Here is supported device list : http://zone.ni.com/devzone/cda/tut/p/id/6417
Starting point for OPC Server :  http://zone.ni.com/devzone/cda/tut/p/id/7450
(8,514 Views)
thank you for your response but I want to do this without using an OPC server.
(8,495 Views)
My Mistake.
In this case, you can use Modbus Library for ethernet or serial interface to communicate with PLC.
http://zone.ni.com/devzone/cda/epd/p/id/4756
(8,491 Views)
Hello Everyone,
                              Me having a question Can we able to communicate with Delta PLC without Lookout server is it possible, i need a direct Communication between Labview and PLC Using TCP/IP
If Possible please help me ......Smiley Indifferent
(7,037 Views)
if you knowned how Communicate with Delta PLC (DVP28SV) using Labview over TCPIP ethernet tell me
(6,129 Views)
