Communicating Between Built LV App.s
Here is an example. Test Mapping.vi and Test Mapping.exe communicate with
each other. Test Mapping.exe can run multiple instances.
Please let me know how it works for you.
Wiebe.
"Neal" wrote in message news:40449905@newsgroups....
> I'm now using UDP and it is working well. However, I am interested in the
> memory mapped file method you mentioned because I may have problems with
UDP
> if there is no network card installed. Could you please send an example
of
> the method you mentioned?
> "Wiebe@CARYA" wrote in message
> news:40431acb@newsgroups....
> > Hi,
> > After doing some test with this method, I think it might be a good
> solution.
> > There are some disadvantages, but also some advantages.
> > Disadvantages:
> > Windows only.
> > One PC only.
> > Uses API's.
> > Low level (unless wrapped).
> > Memory errors when changing control type (during development).
> > Advantages:
> > Fast, little overhead.
> > Full control over synchronisation etc.
> > Can also be used from other languages.
> > All applications can read or write to the "global" at will.
> > Use as many applications as you like.
> > If you're interrested, let me know.
> > Regards,
> > Wiebe.
> > news:403f0d05@newsgroups....
> > > HI,
> > > You could use the windows (MS only) way; by using memory mapped
files...
> > > Regards,
> > > Wiebe.
news:403b6c93@newsgroups....
> > > > I have several built LabVIEW applications that I need to exchange
data
> > > > between when they are running simultaneously on the same PC. Data
> > Socket
> > > is
> > > > probably one of the best ways to accomplish this task but it
requires
> > some
> > > > extra installation and file handling that could complicate things
for
> > the
> > > > end user.
> > > > Does anyone have a better suggestion for communicating between built
> > > LabVIEW
> > > > App.s?
[Attachment Test Mapping.zip, see below]
Message 11 of 19
(2,243 Views)
To get access to TCP/IP, UDP etc. on a PC without a network card you can install a virtual network card / loopback card. As far as I remember you can find it as an option if you try to add a network card in the add device panel...
We've used this on some occasions to be able to use our tcp/ip based client/server solutions on PCs without a network card.
To comment on the que thread: The OpenG Toolkit includes a remote que solution. I highly recommend it, you can find it on www.openg.org
Message 12 of 19
(2,045 Views)
It will work fine but still requires TCP for VI Server operation...
LabVIEW, C'est LabVIEW
Message 13 of 19
(2,045 Views)
Which he will have available if he installs a loop-back card driver (comes standard from Microsoft)...
Message 14 of 19
(2,045 Views)
Thanks for your example code. I tested it against the UDP code that I wrote
and the UDP was about ten times faster than the memory mapped file method.
For speed reasons I think I'll stick with UDP. If I ever need a simple
Windows method on a computer that has no networking support I will use the
memory mapped method. Thanks again for your help.
news:4044b740@newsgroups....
> Hi,
> Regards,
> Wiebe.
the
> UDP
> of
> > > Hi,
> > solution.
> > > Disadvantages:
> > > Windows only.
> > > One PC only.
> > > Uses API's.
> > > Advantages:
> > > Regards,
> > > Wiebe.
> > > > HI,
> files...
> > > > Regards,
> > > > Wiebe.
> data
> > > Socket
> > > > is
> requires
> > > some
> for
> > > the
> > > > > end user.
built
> > > > LabVIEW
> > > > > App.s?
Message 15 of 19
(2,243 Views)
That's a supprise to me. The memory mapping can only be used with lot's of
overhead, but I guessed UDP had even more overhead... It seems not to be the
case...
Thanks for letting me know.
Wiebe.
"Neal" wrote in message news:404c9b95@newsgroups....
> > Hi,
with
> > Regards,
> > Wiebe.
> the
with
> > UDP
example
> > of
> > > > Hi,
> > > solution.
> > > > Disadvantages:
> > > > Windows only.
> > > > One PC only.
> > > > Uses API's.
> > > > Advantages:
> > > > Regards,
> > > > Wiebe.
> > > > > HI,
> > files...
> > > > > Regards,
> > > > > Wiebe.
exchange
> > data
Data
> > > > Socket
> > > > > is
> > requires
> > > > some
things
> > for
> > > > the
> > > > > > end user.
> built
> > > > > LabVIEW
> > > > > > App.s?
Message 16 of 19
(2,045 Views)
Neal,
There's a "wait 1 ms" in "Wait For Write.vi". It is there to prevent 100%
proccessor load, but it should not be executed the first iteration.
After adjusting the VI, I get a typical 10X speed up (16X for read, 9.1X for
write)!
Wiebe.
news:404d91b3@newsgroups....
> Hi,
the
> case...
> Regards,
> Wiebe.
method.
the
> > > Hi,
> with
> > > Regards,
> > > Wiebe.
in
> > the
> with
> > > UDP
> example
> > > of
> > > > > Hi,
> > > > solution.
> > > > > Disadvantages:
> > > > > Windows only.
> > > > > One PC only.
> > > > > Uses API's.
> > > > > Advantages:
> > > > > Regards,
> > > > > Wiebe.
> > > > > > HI,
> > > files...
> > > > > > Regards,
> > > > > > Wiebe.
> exchange
> > > data
> Data
> > > > > Socket
> > > > > > is
> > > requires
> > > > > some
> things
> > > for
> > > > > the
> > > > > > > end user.
> > built
> > > > > > LabVIEW
> > > > > > > App.s?
[Attachment Wait For Write.vi, see below]
Message 17 of 19
(2,045 Views)
I had already taken out the 1ms wait when I ran the tests. I attached the
VIs I used for testing both the UDP and memory mapped methods. I ran it
again today and although my UDP tests were a lot slower than the last time I
ran it, they were still 2x faster than the memory mapped tests. The only
reason for the UDP slow down that I can think of is the fact that the last
time I tested it I was in an airport and was not connected to a Network.
P.S. If you post another VI please zip it first. VI files get blocked on my
computer for security but zipped files still make it through.
news:404d951a@newsgroups....
> Neal,
for
> write)!
> Regards,
> Wiebe.
> > Hi,
of
> the
> > case...
> > Regards,
> > Wiebe.
> method.
simple
> the
> > > > Hi,
> > with
> > > > Regards,
> > > > Wiebe.
interested
> in
> > > the
problems
> > with
> > > > UDP
> > example
> > > > of
> > > > > > Hi,
good
> > > > > solution.
> > > > > > Disadvantages:
> > > > > > Windows only.
> > > > > > One PC only.
> > > > > > Uses API's.
> > > > > > Advantages:
> > > > > > Regards,
> > > > > > Wiebe.
> > > > > > > HI,
mapped
> > > > files...
> > > > > > > Regards,
> > > > > > > Wiebe.
> > exchange
> > > > data
> > Data
> > > > > > Socket
> > > > > > > is
> > > > requires
> > > > > > some
> > things
> > > > for
> > > > > > the
> > > > > > > > end user.
between
> > > built
> > > > > > > LabVIEW
> > > > > > > > App.s?
[Attachment UDPTests.zip, see below]
Message 18 of 19
(2,045 Views)
Neal,
OK, I'll zip next time..
I'm sure you've noticed that if you only need to write strings, there is
room for optimalisation. Because data can have \00 in it, there is need for
interlocking (the "writing" tag, that "Wait For Write" is waiting for). If
you only need to write one string, windows will probably do this
interlocking for you, saving several ms per run.
Anyway, another thread (previously posted) is asking for memory mapped
files, so the code is probably getting used. (Nothing better that home made
code being put to use).
Wiebe.
"Neal" wrote in message news:404ddb60@newsgroups....
I
my
> > Neal,
100%
> for
> > write)!
> > Regards,
> > Wiebe.
> > > Hi,
lot's
> of
be
> > the
> > > case...
> > > Regards,
> > > Wiebe.
I
> > method.
> simple
use
> > the
> > > > > Hi,
communicate
> > > with
> > > > > Regards,
> > > > > Wiebe.
> interested
> > in
> > > > the
> problems
> > > with
> > > > > UDP
> > > example
> > > > > of
> > > > > > > Hi,
> good
> > > > > > solution.
> > > > > > > Disadvantages:
> > > > > > > Windows only.
> > > > > > > One PC only.
> > > > > > > Uses API's.
> > > > > > > Advantages:
> > > > > > > Regards,
> > > > > > > Wiebe.
> > > > > > > > HI,
> mapped
> > > > > files...
> > > > > > > > Regards,
> > > > > > > > Wiebe.
> > > exchange
> > > > > data
PC.
> > > Data
> > > > > > > Socket
> > > > > > > > is
it
> > > > > requires
> > > > > > > some
> > > things
> > > > > for
> > > > > > > the
> > > > > > > > > end user.
> between
> > > > built
> > > > > > > > LabVIEW
> > > > > > > > > App.s?
Message 19 of 19
(2,045 Views)
