Communicating two real time targets over TCP/IP
Hello everybody
I need to communicate two RT targets over TCP/IP protocols
I have two sbRIO board connected with a single host PC via Ethernet router
and I have two IP address of those two targets how can I make RT-RT ping using TCP/IP..
syed irfan
(2,974 Views)
What exactly is your question? The "ping" protocol does not use TCP, it uses ICMP. I do not know of a way to send an ICMP ping from an RT system.
You can use TCP to send data between RT targets. The TCP functions work the same way on RT that they do on other platforms. See the TCP examples supplied with LabVIEW.
(2,964 Views)
HELLO Mr.
I am building a redundant system using two sbRIO's
so I want to establish a kind of communication between RT VI's of two targets
to accomplish a kind indication that one target is running or not and and the status should be displayed in other target
 As I am using RT whether the IP address of the two targets has any role to play in this communication via TCP/IP
(2,956 Views)
Accepted by irfan789
In order to open a TCP connection, you need to supply the IP address of the remote machine. It does not matter what operating system the remote machine is running. If that does not answer your question, then I do not understand what you are asking.
(2,947 Views)
