Communicating with Oracle database
I am not a database expert, but I know a little. I built a database of several tables in Oracle 10g for Windows, and now I need to be able to interface to it from LabVIEW.  Is there any detailed documentation? An example to illustrate how to connect to an Oracle database, insert row in it, and to query from it would be very helpful. Thanks
(3,342 Views)
You can install the ODBC driver (download from Oracle website) and then use the Database connectivity toolset. If you don't have the DB connectivity toolset you can also use LabSQL.
Daniel
(3,335 Views)
