ivi.dll problem because ivi_support_c.dll could not be found
Hi all:
I have a labview program to controll the HP6613C DC power source, written on Labview 6. It used the vi files of hp66xxbc.llb. It is working well on the old version labview.
When I run this program in Labview 8.2 on a new computer, the error message is "This application has failed to start because ivi_support-c.dll was not found. I have copied the ivi.dll and ivi_support_c.dll to the new computer. I have tried copying them into the Labview 9.2 folder or win32/system. However, it doesn't work.
Could you see what wrong it is?
Thank you.
Jay
(3,293 Views)
It's never a good idea to just copy a few dlls between computers. Have you tried doing an actual install of the IVI Complance Package?
(3,286 Views)
Hi Jay,
Did you install the driver for LabVIEW 8.2? You can find the installer here. Hope this helps. Thanks!
Ebele O.
(3,278 Views)
Thank you!
Jay
(3,268 Views)
