This widget could not be displayed.
Communicating with a web browser to download compressed folder
I am currently sending a URL to call a .php file on a server. The php file is used to prompt a series of commands.  The server is located on another computer and the php operations normally send a compressed zip folder to my computer if using a browser.  It brings up the normal download dialog box acknowledging a download to my computer.  If I call the php file through LabVIEW, it sends back a binary file or text that contains all of the contents of a compressed folder - only in an unreadable format (see attached).  I believe the web browsers have something built in that acknowledges the files and brings up the download dialog box, that I am missing in my LabVIEW program. I am pretty new at communicating with a webserver in Labview. Is there any way for Labview to take this binary text and convert it to a zip?  Am I missing a step in order to download the zip folder to my computer with LabVIEW?  Attached is the script that I get in response in Labview.
(2,809 Views)
Accepted by topic author LabViewRookie08
All files are binary. It's a misconception that there are "text" files. Files are just a sequence of bytes, regardless of the extension. In your case you should be able to take the array you get from the method and wire it directly to a Write to Binary File function. Have you tried that?
(2,791 Views)
Prefect! Thanks.
(2,780 Views)
