Communication Problem in Mitsubushi PLC A2SH with OPC 4.5.1
While communicating with Mitsubushi PLC A2SH thru OPC 4.5.1 , it displays time out error , the settings of the Com port of the system is Baud = 9600, Parity = odd
Data bits = 8 Stop bits = 2, Flow Control = None . The same setting is done in the OPC & Mistubushi PLC Comm protocol. Iam using Labview DSC to communicate with PLC with OPC 4.5.1. How do i solve this Comm Problem in what steps.
(3,170 Views)
You might increase the 'Recieve timeout' from 250ms to some higher values on the object (driver) and you might increase in Options >> Serial Ports... >> Receive Gap from 20 to a bigger value like 50.
Hope it helps.
Roland
PS: I've not tried it with this particular PLC, though.
(3,170 Views)
