Spreadsheet: how can I store test results from different tests in the same central spreadsheet?
I am looking to gather test data using LabVIEW. I then want to store all the data in the same spreadsheet, a kind of central data base. I know how to store single test data in a spreadsheet but I can I get the software to write new data in the same file without over writing the old data?
(2,898 Views)
My first recommendation is that if you need a database--use a database not a spreadsheet. A DBMS isn't that hard to use and could pay big dividends in the future.In any case, to answer your question directly, it sounds like you are writing tab-delimited data to a text file that you will then open with a spreadsheet program. On the file write vi is a boolean input that specifies whether the new data should be appended or overwrite the existing data (the default is to overwrite). Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,898 Views)
Can I write to a file stored remotely on a network server, like a MS Access file?
(2,898 Views)
Assuming an ADO interface, yes. All you have to do is setup a DSN that points to the right file...
Mike...
LabVIEW Champion
(2,898 Views)
I agree the database method is the best. However, if that's not feasable, why not format your data so that each source shows up in a different column. It will require a couple of transpositions, but it's fairly easy.
Eric
Eric P. Nichols
P.O. Box 56235
North Pole, AK 99705
(2,898 Views)
I'm new to LabVIEW, so please forgive me. Is this possible without the database connectivity toolset? What is a transposition?
C
PS thanks for the help!
(2,898 Views)
Yes, you can access databases without the connectivity toolkit. Search online for the "LabSQL" toolkit. It's free an is an excellent way to tie into a database. It even comes with a demo that used Access. In terms of your other question, transposition can be thought of as logically flipping a 2D array such that row 0 becomes column 0, row 1 becomes column 1 and so on. Mike...
LabVIEW Champion
(2,898 Views)
