Communication between Labview 2024 and Inclinometer with CAN Open messages
Hi i've the followwing issue:
I need to send/recive Can Open messages from Labview 2024 to Inclinometer board using Peak CAN usb adapter.
I tried downloading and using the Can Open NI libraries, but it seems that they are unable to communicate with the Peak (it gives me the error in the attachment when I try to open connection to the Peak,i think it's because Peak isn't configured in the NI MAX but I don't know how to configure it), instead through the CAN Basic libraries I can communicate with the Peak but it only sends simple CAN commands, not CAN Open.
How can i do?
(951 Views)
Hi Dok,
Yes, those old CANopen library wants to use NI CAN hardware (only)…
You cannot configure non-NI hardware with MAX, as MAX is dedicated to configure NI hardware.
There's no attachment with your message…
How can i do?
Which "CAN Basic" libraries are you talking about?
Peak offers its own API, that you can/should use with their hardware.
And CANopen also uses "simple" CAN messages, it "just" relies on using certain ArbIDs with a well-defined message content. So you could create your own CANopen driver by sending/receiving "simple" CAN messages…
(947 Views)
I have manually downloaded and inserted into Labview some libraries from the PEAK website (attached image)
that allow me to communicate with the CAN device, so are you telling me that I can also use these libraries to send CAN Open messages and not just CAN?
(945 Views)
Hi Dok,
So you are using the PCAN Basic API. (Please be as precise as possible…)
Well, in the end yes.
Examples:
  • to manage the CANopen network you use the NMT message, with an ArbID 0x000 and 2 bytes payload
  • SDO messages start at ArbID 0x600 (+ NodeID added)…
I don't say this will be easy (or even recommended), but it would be possible. I did that sometime ago in cRIO FPGA for a NI9853 CAN interface…
(936 Views)
Ok thanks for the answer, so if i have this template for sending the CAN Messages how can i compile those parameters in order to send CAN Open Messages?
(922 Views)
Hi Dok,
You don't "compile parameters", you provide them.
I don't have PCAN hardware or software, so you need to look for this cluster definition on your own. (We cannot edit/debug/run images in LabVIEW!)
Again: that cluster (most probably) defines the CAN message, containing items for ArbID and Payload…
(918 Views)
