Communication with FANUC CNC oi-TF using NI OPC Server
I am trying to communicate with FANUC CNC oi-TF using NI OPC server to get data from CNC. To communicate we need FANUC FOCAS library files. I have those files in the right location. But when connecting with CNC I am getting an error saying "Fanuc Focas Ethernet Unable to start the GE Focas Data Window Library services". If anyone worked with this CNC kindly help me in this issue.
Note: when choosing device in OPC server it doesn't show oi-TF model, so I am choosing open model to connect. But LabVIEW help shows oi-TF is supported.
do_what_you_like
(6,911 Views)
Accepted by Mando_25
I have got the solution for the above mentioned issue. I have also attached a document which includes the procedure for communicating LabVIEW with FANUC CNC using OPC Servers.
do_what_you_like
(6,861 Views)
Looking through your documemt I think you mixed up something.
32-bit DLLs belong into the SysWOW64 folder while 64-bit DLLs belong into the System32 folder.
Confusing? yes indeed but that is how Microsoft decided it because of somewhat confusing backwards compatibility concerns.
Rolf Kalbermatter  My Blog
(6,621 Views)
No . It is not mixed up. It is working fine...
do_what_you_like
(6,590 Views)
From where can i download Fanuc focas library.
(2,397 Views)
