Communication with RMX-4120
Hello everyone,
I am developing a HAL for some PSUs. Two of the functions in this HAL are: reading if the output is enabled or not, and reading the regulation mode (constant current or constant voltage) which the PSU is working with.
The problem I encountered is that in the driver of the RMX-4120 there aren't functions that return this information (or I haven't found them).
Since the communication with this instrument is via VISA, I could program it myself sending the corresponding commands, but the manual of the RMX-4120 does not have the commands to communicate with it. I'm a little bit puzzled because I don't know how to get this information. (Information that you can actually see in the display of the RMX).
Does anyone know how I could get this information programmatically? Or where I could find the specific commands to communicate with the RMX?
Thank you
(1,571 Views)
Accepted by michberk
Have you tried to query the according setting?
For Output Enable this would be likely: ":OUTPut?;"
Accordingly for Output mode: ":SYSTem:CONFigure:STARtup:PRIority?;"
Rolf Kalbermatter  My Blog
(1,527 Views)
Thank you so much! This queries worked!
(1,481 Views)
