Communication with VWR balance using LabVIEW and VISA
Im trying to connect to VWR balance using visa. Its works just fine in C# but when I try to convert the code to LabVIEW its does not work
The c# setup is:
port= new SerialPort("COM4",9600, Parity.Odd,8);
port.DtrEnable = true;
port.RtsEnable = true;
port.Handshake = Handshake.XOnXOff;
in LabVIEW :
Any suggestions?
(1,144 Views)
Hi Michael,
@Michael.Koppelgaard wrote:
Any suggestions?
Please explain what exactly "does not work"…
(1,135 Views)
I'm noget getting any data from the VISA READ buffer
(1,126 Views)
Any error on the error cluster?
Do you get something if the lenght if 1 instead of 100?
(1,093 Views)
No error on the error-cluster. And I can’t explain why but now it works😊
(1,047 Views)
Also show the C# code that actually sends the command, and enable the "Display Style" glyph on the string constant in LabVIEW if you really have to post an image/snippet, or post the VI instead, preferably backsaved to LabVIEW 2018 or similar.
Rolf Kalbermatter
My Blog
(1,035 Views)
