labview create dll in Windows11 22H2 Error
building shared library...
Pop-up window,click OK,build Errors
Message 1 of 12
(2,451 Views)
LabWindows/CVI messages are rare in LabVIEW....
Pretty sure it's not related to LabVIEW...
Message 2 of 12
(2,408 Views)
I think there was one build I had that required a LabWindows/CVI toolkit of some sort, but that's it.
To the OP:
What happens when you delete that file?
Bill
CLD
(Mid-Level minion.)
Message 3 of 12
(2,390 Views)
Thanks!
Message 4 of 12
(2,369 Views)
The messages are rare indeed but the DLL build does require a C toolchain and the according build step invokes (or at least invoked in the past) a version of the CVI runtime engine with built in compiler.
While a LabVIEW DLL is for most of the part simply an archive of the compiled VIs, there needs to be a stub function compiled in C for every exported DLL function, that locates the correct LabVIEW runtime and then invokes the compiled VI resource through it, possibly massaging any memory buffers (arrays and strings) between the configured C parameter type and the native LabVIEW datatype and vice versa for indicators.
Rolf Kalbermatter  My Blog
Message 5 of 12
(2,326 Views)
OK, so it does seem to come from LabVIEW.
The relocatiob of UserTemp to E:\ could be a problem.
Changing the temp directory should be possible, but things aren't always as they should be...
It is suspicious...
Message 6 of 12
(2,302 Views)
The default temp directory is set test, in the same case, only the folder path different
Message 7 of 12
(2,265 Views)
I don't know what that means.
The path is different, and there's a related error. It's suspicious.
Somewhere some code might still be using the old temp folder. That would be a bug, but not unlikely.
It you'd (temporarily) revert the temp folder to its original path, you'd know for sure if this causes the problem.
If the non-default temp directory does cause the problem, you could make a link from the temp folder's parent to the new temp folder. That would put your temp folder on the new location, and application would still be able to use the old folder. There might be scenario's where this doesn't work, so I'd revert the folder first. Take it step by step...
Message 8 of 12
(2,244 Views)
Use "%USERPROFILE%\AppData\Local\Temp" to set the default directory,
Same question
Message 9 of 12
(2,226 Views)
Same question
Well at least now we know for sure...
Message 10 of 12
(2,210 Views)
