Communication with Zebra printer
Im willing to communicate with a zebra printer (ZD421) that uses a usb type communication (USB B to USB A ) . the problem is that the printer does not show in NI max , and i didnt know how to use VISA to open a communication with it.
(4,114 Views)
Hi Amenii,
I scanned a couple of the manuals available on the Zebra website (User GuideZebra Programming OptionsGeneric list of downloads) and it seems like there are several options, especially depending on your configuration and what you're trying to do.
So rather than trying to guess at how to do something you don't need, can you clarify/explain what you're trying to do? What you want LabVIEW to do with the (label?) printer?
(4,083 Views)
Have you looked at the dozens of posts on this forum about Zebra printers?
Search the community for "Zebra"- NI Community
(4,059 Views)
What specifically are you trying to do? You can look at this post where I had posted a USB solution which will work with USB and Zebra printers. You would need to use ZPL to send the label format to the printer.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(4,044 Views)
