02-14-2022 04:58 AM
Hey, im working on a project where i want an optidrive VFD to communicate to myRIO and be controlled through labview. I only need simple operations like start/stop, manage rotation direction and speed. Did anyone did anything like this before?
Thanks!
VFD: https://inverterdrive.com/file/Invertek-Optidrive-P2-Manual
myRIO: https://www.ni.com/pdf/manuals/376047c.pdf
02-14-2022 08:34 AM - edited 02-14-2022 08:35 AM
Your Optidriver has a serial RS-485 port that can be talked to with Modbus RTU. Your myRIO-1900 does have UART ports but only in 3.3V LVTTL level. So you need an external 3.3V LVTTL to RS-485 converter too. Something like this would work: https://www.hicomponent.com/5V-3.3V-ttl-to-rs485-converter-uart-to-rs485-converter.html
You might also be able to use an FTDI RS-485 to USB cable but if you never have played with Linux before, which is the OS running on the myRIO-1900, it might be too much hassle to get the USB adapter properly recognized. It is not always a plug and play experience but sometimes a plug and pray one.
After that you need one of the several available LabVIEW Modbus libraries to start to try to talk to the Optidrive after you configured it through its display to communicate with Modbus RTU.
