Communication with a SINAMICS G115D Drive over Profinet in LabVIEW
Hello everyone,
I’m working on integrating communication with a SINAMICS G115D drive directly over Profinet in LabVIEW. I’m using the documentation "SINAMICS_LabView_connection" from Siemens as a reference, which explains how to implement this connection. However, I’m facing several challenges and can’t get everything to work as described.
Here are my questions, and I hope you can help:
  1. General Functionality
    Is it even possible to directly communicate with a G115D drive over Profinet as described in the Siemens documentation?
  2. Using the GSDML File
    Can I use the GSDML file available on the Siemens website?
  3. Address Information
    Where can I find information regarding the "input_address" and "output_address" needed for the communication in LabVIEW? Are these addresses provided in TIA Portal or elsewhere in the Siemens documentation?
  4. Special Requirements
    Are there any additional settings or configurations I need to consider to establish the communication successfully?
My goal is to achieve the following setup:
  • A direct Profinet connection between the G115D and LabVIEW.
  • Control and data acquisition of the drive directly through LabVIEW.
Thank you in advance for any help or suggestions! I would also appreciate hearing from anyone with experience with a similar setup.
Best regards
Marco
Message 1 of 1
(618 Views)
