how to calculate total fluid
hi i am using flow meter to monitor the flow rate its output of 0-10v if (1 volt = 1lpm & 10volt=40lpm) i want  to calculate the total fluid go's throug the pipe
Message 1 of 10
(1,138 Views)
What is the model of the flow meter.  We will need to check the specs of the device to get the scaling (0-1V = 1lpm the next 9 Volts get you 39?  Some missing data here )  the rest is just simple calculus to integrate over time.
Message 2 of 10
(1,133 Views)
sorry what i try to say the sensor give (0-10v 0lpm -40lpm)
Message 3 of 10
(1,129 Views)
That makes more sense. Just multiply the voltage by 2/3 to scale it as Liters per Second and do the integration over time to get Liters. You do know your sample rate in seconds right?
Message 4 of 10
(1,122 Views)
could you please make vi to find the total fluid
Message 5 of 10
(1,116 Views)
find the attchement for what i done to fine the total fluid
Message 6 of 10
(1,108 Views)
-it should be divided by 60 not multiplied by 2/3 to get L/s
-cannot open the file, its LV2024, may want to save for earlier version
-the whole thing sounds like a homework question, just saying
Message 7 of 10
(985 Views)
adding to that, flow meters have totalisers. You can read the value from there. Need some sort of a protocol then (HART, modbus, what not)
Or, set it for pulse output, count pulses. Say 1 plulse per L. Same like bean counters.
Message 8 of 10
(965 Views)
The volume will be calculated by integrating the Flow meter waveform over time. The area bellow the FLOW waveform is the volume.
Message 9 of 10
(959 Views)
could run a loop every 1000ms sharp. Turn the value into absolute (but 0-10V should be 0-40L anyway). Then add into a shift register, homework done. Time to watch some doomer music.
Message 10 of 10
(947 Views)
