Communication with camera link camera (VieWorks)
Hello together,
I have a problem with the communication with a VieWorks camera Link camera. I use the PCIe1433. I attached my sample program (Kommunikation_mit_Kamera.vi). The program should read the exposure time. Thats all. After "IMAQ Get Camera Attribute.vi" the error cluster has a red status. I don't get the amount of the exposure time. Why? What can I do?
With the second attached sample program I get a live image, without problems.
Do someone has a idea?
Many thanks in advance.
LV2012
Message 1 of 25
(5,755 Views)
Hey,
what are the error codes you get? Did you check the Camera Attribute which is the attribute name as documented in MAX? Is it : get<cr> Can you put up a screenshot of your MAX Attributes?
Best Regards
Gregor
Message 2 of 25
(5,655 Views)
Hi GregorP,
sorry my late Answer.
In the attachments is the error code and MAX Attributes?
Can you see my mistake?
Thank you very much
Greetings zäpfle
Message 3 of 25
(5,638 Views)
Got same problem.
Can't set camera parameters in MAX.
George Zou
Message 4 of 25
(5,602 Views)
Hello together,
unfortunately I haven't a solution untill now. I only can controll the camera with the 4 commands, which are in the MAX (see "MAX_Attributes.png", previous message).
In the attached vi is the code (i got this solution from the NI support). But the VieWorks camera has much more commands.
How can I use the rest of the commands?
I hope anybody has a solution, because it is a urgent problem.
Regards Zäpfle
Message 5 of 25
(5,576 Views)
Vieworks has their own configure exe.
It can be used to configure the camera manually.
George Zou
Message 6 of 25
(5,569 Views)
Hello Zou,
thanks for your answer.
I want that a LabVIEW program configure the camera. I have the configuration exe (see attached pdf). But I want that during the LabVIEW Program is running, the configuration could change (e.g. Exposure time) through the program.
Do you see any possibility to do this?
Greetings zaepfle
Message 7 of 25
(5,559 Views)
Hello together,
I have a camera file (see attachment). In the MAX I can see only 4 camera attributes, but the VieWorks camera has much more. Should I generate a new icd file with the NI file generator (to see more attributes in the MAX) or is the attached camera file OK?
greetings zaepfle
Message 8 of 25
(5,533 Views)
Can somebody gives me some advice?
greeitings zaepfle
Message 9 of 25
(5,496 Views)
When you set the attributes in MAX manually, does camera attributes actually changed?  You can use Vieworks' config app to verify this.
George Zou
Message 10 of 25
(5,484 Views)
