Como eu faço pra usar uma imagem dos meus arquivos
"So, LVNinja,
I need some help. I tried to make this work using the 'File Dialog,' but I’m not sure how to set the path for the image I want to use. Just to clarify, I create the image in the same VI, and then I plan to insert it into Excel."
This is what I'm doing.
In this part, I create an image of the visible items in the VI.
 Then, I send all the information I gathered to the 'MS Office Report,' with the idea of using the same file created to insert the image I made. Understand?
Message 11 of 18
(537 Views)
isn't the path given in your vi that generates the image ?
Message 12 of 18
(518 Views)
"Ok, I tried to make this work, but for some reason, when I put it in a sequence structure, it just doesn’t work. (Well, it wasn’t fully working before, but now there’s no response at all.) So, if you could help, I’d really appreciate it.
Just to explain, here’s the structure:
  • The first sequence creates the image.
  • The second prepares the information I gathered.
  • The third sequence, which isn’t working at all, is supposed to create the Excel file, send this information to a template, add the image to the same template, and save everything.
The idea is to insert the image in an empty space in the template and then display the arrays from the previous sequence. Now, I’m pretty lost."
Message 13 of 18
(509 Views)
Is this some kind of joke ?
When i finally make it work, this is what happend...
Message 14 of 18
(489 Views)
"Why is the image formatted like that? Wasn’t it supposed to be fully expanded? Well, anyway, this is what I was able to do.
Now I just need to fix the image formatting, and it’ll be DONE."
Message 15 of 18
(477 Views)
I dont even know how this is possible, but i got worse...
Message 16 of 18
(473 Views)
Hi Marcus,
Why worse?
Now you have placed the PNG file content in your Excel sheet… 😄
Message 17 of 18
(453 Views)
i see.
Message 18 of 18
(449 Views)
