05-11-2017 11:12 AM
i'm trying to run a vi on the FPGA of my CRIO-9067. For some reasons I fail to understand, every time I try to run the vi, as soon as the loading window "preparing for interactive executions" pops up, another pop up window opens basically telling me that the chassis is in "scan interface mode".
However, when i go to the properties window of the chassis, the option "FPGA interface" is properly checked.
In my opinion something is wrong with the CRIO, since after I experienced this problem I developed another project on another device (CRIO-9075) and everything work fine.
Has anyone experienced something similar?
Luca
05-11-2017 12:24 PM
Not a perfect solution but when I setup a RIO from MAX, I always leave out the scan engine. It can't be in scan engine mode if there's no scan engine installed right?
05-11-2017
03:44 PM
- last edited on
08-12-2026
11:50 AM
by
Content Cleaner
Maybe the FPGA needs to be deployed for the setting to take? Right-click on the cRIO and have it deploy.
I am not a fan of FPGA Interactive mode, lots of time is potentially lost waiting to compile. Is this something you can test in simulation mode?
FYI, good cRIO ref: http://www.ni.com/pdf/products/us/fullcriodevguide.pdf
